60 Users Online (59 Members):
Forums >> General Discussion >> Revit Project Management >> Printing Thin Lines
How can I print in thin lines instead of the Revit default thick lines? Is there a way to do that? Thanks for any help.
Lines are printed according to how you set them in the linetypes and categories. The thin/thick setting is only a view setting on your computer - not used in printing.
Unfortunately you can't print thin lines directly from Revit, however an easy bypass is to just take a screenshot with thinlines enabled and print that image instead.
If you want a view to always print with all thin lines -- make a view template with all category and sub-category cut and projection lines overridden to a thin type.
Hey all - I made a video illustrating the solution to printing thin lines.
https://www.youtube.com/watch?v=3JGAU7yAf3c&t=25s
Enjoy and Revit on!
Here is the clickable link:
Printing thin line problem |
Thu, Apr 9, 2015 at 4:45:45 PM
Lines too heavy in perspective view |
Wed, May 1, 2013 at 6:36:38 PM
lines missing |
Fri, Mar 11, 2016 at 2:52:46 PM
Black lines printing grayscale in PDF |
Fri, Oct 10, 2014 at 4:46:46 PM
Printing question |
Fri, Dec 14, 2018 at 3:20:22 PM
Members: | 2000323 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
