43 Users Online (42 Members):
Forums >> Workflow & Implementation >> API & Third Party Apps >> Convert Archicad into Revit
2 Posts No Rating |
Hi. We are using Revit 2010. The architects model is in Archicad. If they export their model to IFC can I import it and use it in Revit? Will it be parametric? Would I be able to turn off their curtain wall and add my own cw grid to the model? I've been reading a lot of threads on this. Seems export to IFC is possible but I haven't gotten a "yes for sure" from anyone who has done it. I appreciate any guidance you can give me. Thanks.
I have not done any of this but as I understand it, no imports can ever become REVIT elements. They may show but they will not be smart.
I had an experience of uisng IFC export from ArchiCAD then import into Revit sometime ago. as I can recall, the IFC wasn't not 100% correct while imported into Revit. some elements could be as wrong categoryies, I think curtain wall elements as examples they will become under generic model category not curtain wall and the curtain grids will be missed. If u just want the IFC import as a reference for carry out the work i think it will be good enough, but if you want to add some works on top the IFC import thatseem to me not a real approprite approach. in my opinion, using IFC for transection is an option without any other option available.
1 Posts No Rating |
Hi. I want to convert an archicad file to revit and you had already done using IFC. However I don't know about how can I using IFC. Please could you tell me step by step how converting archicad to revit?
Converting a Revit v 8.0 file into Archicad v10.0 |
Tue, Mar 24, 2009 at 4:21:51 PM
Converting ArchiCAD objects into Revit families |
Thu, Jan 17, 2013 at 9:43:29 AM
Revit vs. Archicad [ 1 2 ] |
Fri, Sep 28, 2007 at 11:57:54 PM
15
REVIT 2009 VS ARCHICAD 12 [ 1 2 3 ] |
Wed, Aug 22, 2012 at 10:03:49 PM
33
Revit vs Archicad |
Mon, Jun 13, 2011 at 5:33:18 PM
Members: | 2005701 | Objects: | 22910 | Forum Posts: | 152188 | Job Listings: | 3 |
