73 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> Surface pattern vs. Render Pattern
2 Posts No Rating |
I have an existing building with utility brick on it that I am attempting to re-create. I have found the correct surface pattern, imported it, and all the joints line up and all of that. My next problem is attempting to find a rendering pattern that matches this surface pattern. Has anyone else encountered this? If so what did you do? Any help would be greatly appreciated!
What kind of pattern is it. If it's not standard you will need to find a map of the brickwork or create one from a photograph.
Surface pattern problem |
Tue, May 18, 2010 at 9:15:56 AM
Surface pattern |
Mon, Sep 10, 2007 at 11:18:01 AM
Surface pattern move/align/adjust problems [ 1 2 ] |
Thu, Sep 17, 2020 at 10:29:33 AM
19
SURFACE PATTERN LINE WEIGHT |
Fri, Mar 28, 2014 at 2:30:00 PM
Surface pattern and Render Appearance Do Not Match |
Tue, May 7, 2013 at 11:44:06 AM
Members: | 2000420 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
