61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Door Swings
25 Posts No Rating |
Hi everyone, I am having issues with adding a parametric door swing on my door family. I can't get the lines for the door to rotate at the origin of the line. I am not sure if I am drawing the lines right, or how to dimension/attach the lines to the reference lines. I attached my file... ~Amy
...I am using Revit 2009
Building families is hard to learn. You must understand that REVIT build associations with what is already in your family. You always want to add reference planes their dimensions (if needed) ... reference lines - their dimensions (if needed) then model elements. With doors and windows, you have to be careful because the wall is already there and it has several elements that things will associate with. I like to build these away from the wall on a refernce plane parallel with the wall. In your case, try aligning your reference line with your right reference plane... not the door.
I'm not sure I understand which lines you are referring to. my issue is I can't get my symbolic line to rotate along the correct axis, if you look at my attachment and flex the lines, the point of rotation moves. I don't want the model to change in 3D just in plan, using lines not masses.
Door swings in RCP |
Thu, Jul 18, 2019 at 5:03:06 PM
creating double door with multiple swings |
Fri, Oct 31, 2014 at 1:44:28 PM
Hide door swings which are visible from floor below |
Wed, May 6, 2015 at 12:16:03 PM
DOOR SWINGS DISAPPEAR HWEN USING A COLOR SCHEME IN REVIT 2011 [ 1 2 ] |
Sun, Jan 13, 2013 at 11:26:10 AM
29
Door swings in 3d view |
Tue, Dec 1, 2009 at 7:41:35 AM
Members: | 1999814 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
