166 Users Online (165 Members):
Forums >> General Discussion >> Revit Project Management >> Help!!! Trouble with printing any raster image (revit 2010)
4 Posts No Rating |
I want to print an image (my company logo), but i just can see it in views and sheets. but i can't print it. The print setup : If i choose vector processing : I can't see the image (in revit 2009 i can print images with this option) If i choose raster processing : i can see the image, but the quality of the picture and all architectural objects are so bad! Please help me, i want to print with vector processing, because architectural objects are much necesary than the logo image. Thanks all comments.
I believe that this issue has been fixed in the latest update for Revit. http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12828862
4 Posts No Rating |
Thanks Tim 123. Now i can see and print the raster images. A differrent problem: i've lost the texture image which is set in another computer. when i reset the path, i can see the preview in the material tab, but in the render image i can't see it. when i check the texture image, it lost again! I've set the path, rendered, and checked it several times but not suscessfully. Please help me...
Textures for projects should be stored in the same location as the central file so all have access to them. Then that has to be mapped in their system. Under settings/options/rendering
Raster Image Content Blank-2010 |
Fri, Aug 28, 2009 at 12:39:02 PM
Raster Image display |
Fri, Oct 10, 2008 at 6:08:26 AM
Revit 2010 Printing Problems [ 1 2 ] |
Wed, Jun 24, 2009 at 11:21:31 AM
16
raster image will not plot |
Thu, Sep 24, 2009 at 8:43:42 AM
Raster Image |
Fri, Jul 31, 2009 at 8:24:24 AM
Members: | 1998656 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
