53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> roof by extrusion RAC 2010
Thu, Jul 9, 2009 at 7:30:29 PM | roof by extrusion RAC 2010
pepsiqueen
pepsiqueen Avatar
This is really pissing me off. In older versions of revit, in a section view you can create a roof by extrusion by drawing the sloped line of the roof then telling revit how wide the roof is.
ow, in 2010, when i am in the section and try to make a roof by extrusion, revit says i need to pick another work plane, and the only options it gives me are all views perpendicular to the one i want to draw the line in. So i tried starting the command in a perpendicular view than the one i wanted to draw in, but that did not work.
So then i tried creating a generic model by extrusion, but apparently that handy command is totally gone from the new revit. WHAT HAPPENED TO GENERIC EXTRUSIONS, SWEEPS, ETC? the 'model mass in place' thing makes no sense.
Oh and did i mention the ribbon thing totally blows?
excuse the rant but i cant make this curse roof!
I'd rather be riding at whistler. or highland. thats good too.
Fri, Jul 10, 2009 at 3:39:29 PM | roof by extrusion RAC 2010
tim123
4 Stars: 19 Votes
Revit was asking politely where you would like the roof to start from, so pick a plane from the list, or pick a plane in the drawing (of course it needs to be perpendicular to the roof).  Extrude the roof.  If this is not where you want it, adjust it in plan.
With regard to the generic model, it would be unlikely that the basics of modelling would suddenly be excluded - you just need to find it.  In the home menu, click on the little arrow beneath 'component' and create in place.  Then you can use all of the modelling tools and categories.
Don't worry about the ribbon - once you're used to it you will feel better.
Barrel tile roof by extrusion
Fri, Jan 14, 2011 at 1:10:17 PM
Why Roof Cutplanes are visible in RAC 2008 and Why not in Revit Building 9
Wed, Jul 16, 2008 at 10:34:18 AM
Revit 2012 Roof by extrusion
Sat, Nov 19, 2011 at 4:49:20 AM
Joining Roof By Extrusion
Mon, Jan 31, 2011 at 8:15:14 AM
Trouble Installing RAC 2010 x64
Thu, Oct 1, 2009 at 3:47:49 AM
Page generation time: 0.6035
