76 Users Online (75 Members):
Forums >> Revit Building >> Technical Support >> cannot fiure out how to make linear light fixure give off linear light
49 Posts No Rating |
I've got a 28' light fixture that still acts like its a down light. I've made sure the right lighting source is used and I make sure the emit from line length is as long as the fixture but there is still a hot spot in the middle of light on the wall. How do you get it to be the same intensity down the length of the fixture?
I would not make a single 28' light, I would use multiple nested families or just multiple families to create the light. I have seen this in the forums before and it seems someone had a decent solution but i cant remember it.
I was hoping to reduce the number of lights so as to reduce the rendering time. But I guess that will be a no go.
1 Posts No Rating |
I found that rendering on settings above Low will eliminate the hotspot efect where on low and draft rendering settings there is a hotspot centered on the linear light source no matter how long or how many lights there are.
Linear lights aren't linear at all? |
Fri, Feb 4, 2011 at 1:54:01 PM
Recessed linear light |
Tue, Feb 3, 2009 at 1:48:45 PM
Linear Lighting |
Wed, Dec 27, 2006 at 2:58:38 PM
Linear lighting fixture |
Wed, Sep 2, 2009 at 2:32:08 AM
Linear lights rendered as spot lights |
Thu, Dec 29, 2016 at 7:18:38 AM
Members: | 2001138 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
