Forums >> Revit Systems >> Technical Support >> Moving Annotation Symbols without moving objects
3 Posts No Rating |
Is it possible to move an annotation symbol in a project (plan view) without moving the object it is attached to (i.e. un-attach the annotation symbol and leave the object in place)? I have a headwall with multiple receptacles, etc. that overlap in plan view, but I can't move the symbols around without moving the actual object. Anybody?
Are they really just symbols or are they nested symbols in a wall hosted family?
3 Posts No Rating |
they are annotation families (which contain generic annotations and labels) imbedded within the family of the receptacle, switch, etc. basically the same way Revit does the annotations by default for receptacles and switches.
As I expected ... they are nested in the family ... which must be wall based. If so - you can't move them because their location is fixed in the outlet/switch/whatever family. If they were a seperate symbol added afterwards, you would not have a problem.
21 Posts No Rating |
I have an "annotation offset" distance parameter and a linear dimension in my receptacle family set up to move the annotation away from the surface without moving the receptacle itself. Default is 0 so it starts out on the wall, but if you need it to move out, you just offset it a foot or so. You could take this in another direction if you want with "annotation offset left/right" and give it positive and negative values depending on which direction you want to move it.
3 Posts No Rating |
thanks a lot guys. I appreciate the input.
3 Posts No Rating |
'You could take this in another direction if you want with "annotation offset left/right" and give it positive and negative values depending on which direction you want to move it.'
This is basically the issue I am working on.. Unfortunately Revit does not allow you to input negative lengths. Meaning, when I tie my annotation to a reference line to one side of my device center line, things work fine, with positive lengths. Positive lengths simply move the annotation towards the reference line. You might think (like I did) that this would mean negative lengths would move it the opposite direction, but Revit does not allow negative lengths.
Anyone know what am I missing here?
Long time daily CAD user, becoming a daily CAD & Revit user who has acquired a few growing pains through the process. |
3 Posts No Rating |
Just a follow up item.. I am using Revit MEP 2011.
4 Posts No Rating |
Make two identical labels in the annotation family.
Assign visibility to a yes/no parameter. For instance, make your standard label on the left side, make a yes/no property that makes visible a copy of the label on the right side. Then a formula for the left-side label that turns it off when the yes/no returns a 'true' value.
Both labels can locate off the same length dimension (from centerline) property, just visibility is controlled by one yes/no parameter.
I'm at home now, but I can scratch up an annotation symbol when I get to work in morning, for a better idea of what I'm saying...or you can just use it and tweak it to your liking, if you want.
I hope I make sense. I know things work right in my head, but putting them into words hardly ever works right; I stumble a lot and leave things out.
(also posted this on CADTutor, hate the copy/pasted text)
Edited on: Mon, May 23, 2011 at 6:30:19 PM
3 Posts No Rating |
That does make complete sense. In fact it was something I looked into briefly, but being new to this, I was concerned that this might require additional work for my other text parameters. I think I will have to give this a shot and see how it turns out.
I do have to say that it makes me feel better that I was on the right track.. that means I am actually learning something.
Thanks!
Moving Family Symbols without moving the family in one instance |
Sat, Oct 12, 2013 at 1:01:06 AM
Changing rotation of annotation on electrical symbols |
Wed, Feb 11, 2015 at 9:11:49 AM
Moving Levels - Annotation only |
Fri, Jan 7, 2011 at 7:34:04 AM
Multidirectional moving of objects w/in families |
Mon, Jun 28, 2010 at 9:08:35 AM
Question about Annotation Symbols |
Wed, Aug 13, 2008 at 6:49:42 AM
Members: | 1999122 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
