71 Users Online (70 Members):
Forums >> Revit Building >> Technical Support >> Brick Wainscot Covers Door and Window Trim
I've searched some older threads but can't find a resolution. I have a stacked wall with a brick wainscot on the bottom and a plaster wall on top. The brick wainscot on the bottom covers the trim at the bottom of the door. Please help. I'm using Revit 2009. I've attached a jpeg as well as the revit file.
Here is a clearer view.
YES__annoying, I know. Sweeps can be a pain... SO... Edit the wall profile, but do not trace around your entire door frame__ just the wainscot portion. see attached, right?
P A R A M E T R I C components
http://www.parametriccomponents.com [open source Revit Content]
http://www.revitcomponents.blogspot.com [blogging for Revit Components] |
Thanks RevirComponents! So I have to do that for each door and window?
I guess if you have to do it for each door and window, it can still be done with the same Edit Profile. It even worked with the window.....I just put a full rectangle in Edit Profile. Thanks RevitComponents!
Stone wall covers door and window trim? |
Thu, Jan 3, 2008 at 8:50:32 AM
Door Trim Parameters |
Fri, Sep 11, 2009 at 12:52:57 AM
Tricky Window Trim |
Thu, Mar 9, 2006 at 1:14:00 PM
RAC 2012: Window Trim Reveal in brick/Stud Wall |
Mon, Jul 2, 2012 at 2:08:10 PM
Door family - opening covers door leaf |
Fri, Sep 30, 2016 at 4:36:46 AM
Members: | 1991887 | Objects: | 22879 | Forum Posts: | 152183 | Job Listings: | 3 |
