Forums >> Revit Building >> Technical Support >> Arched Columns
Wed, Mar 18, 2009 at 5:50:39 PM | Arched Columns
djstarr14
What would it take for me to create this kind of effect? I want to make that arch made of stone. To create it I used modeling, create, door, solid form sweep, loaded my own profile (simple, round).
Is there a way I can make that arch made of stone? Also is this the best way to do it? I appreciate any advidce. Thanks
Thu, Mar 19, 2009 at 2:12:25 PM | Arched Columns
tim123
4 Stars: 19 Votes
You will have to use a drafting pattern to achieve this, so you may have to change the model pattern to a drafting pattern and adjust the size to suit.  The material can then align to the element.  The rendering should also align.
Arched Curtain Wall Arched Mullions
Wed, Jan 22, 2020 at 2:13:08 AM
Arched Window
Thu, Sep 29, 2005 at 1:20:55 AM
arched curtain wall
Mon, Feb 26, 2007 at 10:17:47 AM
Seeking Advice:Creating Arched Opening with Tapered Columns
Thu, Jan 13, 2011 at 7:15:32 PM
Arched wall lintel over an window
Sat, Jan 10, 2015 at 1:38:47 AM
Page generation time: 0.2750
