57 Users Online (56 Members):
Forums >> Revit Building >> Technical Support >> Maintaining interior dimensions when changing walls
50 Posts No Rating |
I have a room whith the following dimensions 12'x11' the exterior wall thickness is 5", ater I change the exterior wall to a with 7" thick wall my interior dimensions become smaller, see screen shots. How can I make the walls to streched to the outside instead of the inside?
62 Posts No Rating |
I think it depends on how the wall is drawn. If you draw it by exterior face it uses that as the base, if you do it by interior it uses that as the base. I think give it a try and see if that helps but if you pick the wall you should be able to change the dimension by typing it in.
Thanks Wheelergc, oh man I have to this one by one because I have more rooms in the project. bommer. I actually drew a square 10'x10' with loc line finish face exterior and still shrunk the room 9'8"x9'8". Thanks for the suggestions. Let me know if you can figure this out.
Edited on: Fri, Mar 13, 2009 at 5:33:22 PM
You can change the location line of the wall type in the element properties to be interior and readjust their positions. You don't have to redraw the walls.
Thanks tim123, That did it.
Changing Dimensions |
Mon, Feb 7, 2011 at 9:02:52 AM
Aligned dimensions for centering curtain wall door |
Fri, Dec 23, 2011 at 6:26:40 AM
Adding Dimensions to new walls in the "New" phase |
Sat, Apr 6, 2013 at 8:09:19 AM
Changing dimensions |
Tue, Dec 22, 2015 at 5:05:09 AM
Changing wall thickness issue |
Thu, Oct 12, 2006 at 11:07:14 AM
Members: | 1999807 | Objects: | 22885 | Forum Posts: | 152181 | Job Listings: | 3 |
