105 Users Online (104 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Changing wall materials
Wed, Mar 11, 2009 at 1:24:12 PM | Changing wall materials
wolberjs
When i select a wall to change the material on that one wall, a couple other wall changes and not the one i selected.  ive tried duplicating the wall and everything.
its proply something real easy, please help.
Wed, Mar 11, 2009 at 1:34:05 PM | Changing wall materials
RevitComponents
RevitComponents Avatar
4 Stars: 22 Votes
Are you making the changes by editing the 'Structure' of the Wall Type?
Try duplicating, renaming, and editing the Type parameters of the Wall Structure/Assembly.
P A R A M E T R I C components
http://www.parametriccomponents.com [open source Revit Content]
http://www.revitcomponents.blogspot.com [blogging for Revit Components]
Wed, Mar 11, 2009 at 1:41:10 PM | Changing wall materials
wolberjs
yeah, im duplicating, renaming, and editing the structure.  but somehow their still connected
Wed, Mar 11, 2009 at 2:36:31 PM | Changing wall materials
3.5 Stars: 391 Votes
It sounds like you need to understand materials.  If you change the material settings - all elements that use that material will change.  Materials can be assigned to any element.
Thu, Mar 12, 2009 at 6:02:34 PM | Changing wall materials
DaveF
WWHub, Didn't the OP say that the one he selected WASN'T chsnging?
Also, could you give me your definition of an element please?
Cheers
Dave F.
Fri, Mar 13, 2009 at 8:05:02 AM | Changing wall materials
By element, I mean anything that has 3D properties other than a line.  Each extrusion inside a family is an element that can be assigned a material.  These are assigned in the family initially but can be over-ridden in the project.
Everything that is assigned a material definition will show the same characteristics (cut/surface/render) unless over-ridden in the view.
The poster was complaining that changing one wall changed them all.  This is what I was addressing.
As far as why this one wall would not change, I would look at over-rides in the view.
Sun, Aug 22, 2010 at 11:14:41 PM | Changing wall materials
ADC94
can you change one wall without all the others changing?
Mon, Aug 23, 2010 at 3:44:13 AM | Changing wall materials
4 Stars: 201 Votes
Select the wall, go to properties, "Duplicate" and give another name to that wall, now you can change the materials ONLY in that wall.
Mon, Aug 23, 2010 at 2:01:52 PM | Changing wall materials
porculator
If you're altering the materials themselves (as opposed to swtiching which material is in the wall) it will affect all walls with that material even if its not the same wall type.  As for why its not changing in the original, it could be a graphic override issue, or it could be that at one point you painted that wall with a different material.  The "painted" layer will remain even if you change the materials of the wall (and honestly I don't know how to change it back other than paint it the new material)
Mon, Aug 23, 2010 at 2:09:17 PM | Changing wall materials
4 Stars: 201 Votes
"(and honestly I don't know how to change it back other than paint it the new material)" - in "Paint" select "By category"
Mon, Aug 23, 2010 at 2:09:47 PM | Changing wall materials
To put / reface an element with it's original defined material after it has been painted, just paint with "default".  Default is the assigned material.
Edited on: Mon, Aug 23, 2010 at 2:10:20 PM
Tue, Aug 31, 2010 at 8:13:34 AM | Changing wall materials
fjtdogeno
fjtdogeno Avatar
5 Stars: 4 Votes
Not only wall shall be duplicated, Material must be duplicated too.
Curtain wall panels changing materials when pinned
Fri, Feb 26, 2010 at 8:46:05 AM
Changing materials
Fri, Oct 4, 2013 at 10:18:56 AM
changing materials in family editor
Thu, Aug 10, 2006 at 6:31:24 AM
Changing materials in family editor?
Fri, Aug 4, 2006 at 11:05:13 AM
Phasing vs materials...Who is the boss when it comes to graphic overrides?
Mon, Nov 12, 2012 at 9:07:55 AM
Page generation time: 1.0173
