84 Users Online (83 Members):
Forums >> Revit Building >> Technical Support >> Sweep Blends / Void extrusion
Has anyone tried to cut a sweep blend with a void extrusion? Is there a trick or can it not be done.
YES__ It can be done... May you provide an image of your specific issue?
P A R A M E T R I C components
http://www.parametriccomponents.com [open source Revit Content]
http://www.revitcomponents.blogspot.com [blogging for Revit Components] |
Please see attached street work. Curb gutter and street to be A/C, like existing no problem. However, the sidewalk which is at present shown as A/C may end up being concrete. The problem is that the propertylines are not radial to the street. I would like to cut the sidewalk back at the property line angle which would be a small triangular amount. I have worked around this by placing a curb at the ends of the sweeps to bury the end condition in.
Void Sweep won't cut extrusion |
Fri, Aug 24, 2012 at 3:02:42 PM
Void Won't Cut Extrusion |
Wed, Feb 13, 2013 at 11:04:26 AM
void extrusion not cutting solid extrusion |
Fri, Oct 10, 2008 at 3:47:43 PM
Tensile Membrane Structures |
Wed, Sep 29, 2004 at 9:00:32 AM
Make void extrusion permanent |
Wed, Feb 9, 2022 at 6:46:57 PM
Members: | 1999278 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
