57 Users Online (55 Members):
Forums >> Revit Building >> Technical Support >> View Rotation - Dimension text
12 Posts No Rating |
Hi all i have rotated a site plan to fit on sheet, fixed the upside down text by ticking off keep readable but is there a way to fix the dimensions which are also upside down? i know i can make a dim style with small text and add text over but this defeats the whole purpose of rotating a view. thanks for any input
? ? ? It sounds like you are still using CAD methods and you have not yet learned the power of REVIT. Did you rotate the plan or rotate the sheet? I think you rotated the sheet. Goto your view and make sure yourview is cropped and the crop region is visible. Click on the crob region boundry and select the rotate icon. Now rotate yourview to what would be correct when you place it on your sheet. All of the dimensions and text will remain readable.
thanks Hub You where correct i did rotate on sheet not in view - i didnt even know about that, well you learn something new everyday. Thanks again
Thank you! I needed that as well
Brilliant. Thank you!! Rarely need to ever rotate things but did not know this.
The best thing is that you don't need to make a new view title type that doesn't rotate!
Dimension Text [ 1 2 ] |
Tue, Jul 8, 2008 at 9:15:07 AM
18
View Rotation on a Sheet |
Tue, Feb 14, 2012 at 1:32:37 AM
Overwriting Dimension with Text |
Thu, Jan 11, 2007 at 11:13:56 AM
Multiline text below dimension |
Tue, May 10, 2011 at 9:32:42 AM
Dimension Text Problem |
Fri, Nov 14, 2008 at 9:41:55 PM
Members: | 2000441 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
