163 Users Online (162 Members):
Forums >> Revit Systems >> Technical Support >> Objects not showing in "fine" detail level
9 Posts No Rating |
I'm still fairly new to Revit, so I might be missing something pretty obvious here. I do electrical design and I am placing duplex and quadruplex receptacles in my plan. If I switch to fine detail level, my quads go away. In medium or coarse, they are there. This is an issue because we show all of our piping/conduit in double line which needs the fine detail level on to see. Is there a reason why the quad receptacles would disappear in fine and not the duplex?
9 Posts No Rating |
I forgot to add that these are not customized objects. These are from the "out of the box" revit library, so that's not something that might have caused it.
YES__ Open the family / edit the family >> select the linework that is not showing up in 'fine detail' >> right-click >> Element Properties... >> Click "Edit" @ Visibility/Graphics Overrides >> Adjust accordingly. VIOLA
P A R A M E T R I C components
http://www.parametriccomponents.com [open source Revit Content]
http://www.revitcomponents.blogspot.com [blogging for Revit Components] |
The rules for when to use the medium / fine switch has not really been established for most families. It doesn't make a difference for walls/floors but it can be set in families. Most family builders treat them the same but it appears that you have found a unique one. Edit the quad family and I am sure you will find it is switched off in fine visibility. Edit that.
9 Posts No Rating |
Awesome. That was it. Thanks a bunch.
fine detail missing on duplicated wall, plan view?? |
Mon, May 1, 2006 at 8:31:20 PM
Any way to show some objects in FINE detail on a coarse detail plan? |
Wed, Apr 27, 2011 at 12:36:11 PM
In "Fine Detail" Wall structure is missing... |
Tue, Sep 22, 2009 at 1:35:38 PM
wall detail not showing in plan view |
Wed, May 22, 2013 at 3:18:27 PM
Moving Detail cuts results in "objects will be deleted" Unacceptable!! |
Mon, May 10, 2010 at 3:42:52 PM
Members: | 1999122 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
