63 Users Online (61 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Tips & Tricks >> Combining Door & Window Schedule; it WORKS!
Tue, Mar 3, 2009 at 9:32:50 AM | Combining Door & Window Schedule; it WORKS!
MARS1276
1 Stars: 1 Votes
Long have I been told that it can't be done.  I have figured out how to do it.
I figured out how to do it!
The first thing you will want to do is edit the tag you are using for the doors and windows.  We use the same tag for both (the Default Window Tag ). But we need to modify this.  So what you do is you change the parameter of the label by adding a new one.
Click on the label, edit the family, add new parameter (we called ours D/W TAG), add it to the label and remove the other one that is there by default (I think it may have been 'Mark' previously), now deselect the label.
 Edit the Family properties of the file itself, add new family type (I named ours door/window tag), add new parameter (Name: door/window tag, Discipline: Common, Type of Parameter: Number) and make it an instance under the 'text' Group.
With that done, choose your doors and windows  you want to schedule.  What you will want to do now is create a shared family group (I labeled ours Door Schedule Items).  Then add parameters under that group.  Here is a list of what I have added.
D/W TAG
Door/Window Finish
Door/Window Finish Letter
Door/Window Frame
Door/Window Frame Letter
Door/Window Frame Finish
Door/Window Frame Finish Letter
Door/Window Type
Door/Window Type Letter
Door/Window Width
Door/Window Height
Elevation Type
You add these to both your doors and windows and your schedule.  As your number of doors and windows grow, so will your schedule populate, giving each their own number.  Here is an example of ours:
Thu, Jan 28, 2010 at 11:32:51 AM | Combining Door & Window Schedule; it WORKS!
Luigiman
I am trying to do what u are saying, but can't help
Wed, Mar 3, 2010 at 12:02:38 PM | Combining Door & Window Schedule; it WORKS!
Luigiman
I got it!!!
Mon, Jun 29, 2015 at 1:11:16 PM | Combining Door & Window Schedule; it WORKS!
CDWdavid
5 Stars: 5 Votes
Hi All,
It is a very old post.
I like to have some inputs for what I'm doing now.
Our office assigns unique numbers for each door, with oval door tag; and window with diamond window tag, then create a door/window schedule.
For example, in Room 101, three doors are labeled 101, 102 and 103; four windows 101A, 101B, 101C, and 101D.
1. I created two types of door tags, one oval, and another diamond.
2. I created all window families by using the door template.
3. I placed "doors" with oval door tags first; then "windows", which are doors also, with diamond tags. After the first window placement, I switched the tag from oval to diamond, and place all subsequent windows.
4. All fields in the door schedule are following our office standard, with two hidden fields "Door" and "Window" for sorting.
It works so far, any inputs are welcome.
Best regards,
Wed, Jan 20, 2016 at 10:15:28 AM | Combining Door & Window Schedule; it WORKS!
mtsche3
ran into same issue.  I edited the window family (which i downloaded a HM frame window from revitcity) and made it a door type.  The tags are the same as doors and shows up on schedule.
see image
Trying to Schedule a door that lives in a Window Family
Thu, Jan 16, 2014 at 12:07:10 PM
Window & Door Schedule
Wed, Feb 29, 2012 at 12:23:01 PM
door in window schedule
Thu, Apr 29, 2010 at 7:47:41 AM
Schedules. How do I avoid having a schedule row for every door, room & window?
Wed, Aug 15, 2012 at 7:24:44 AM
Window & door tag formatting
Tue, May 25, 2010 at 9:27:07 AM
Page generation time: 0.9970
