61 Users Online (60 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Section View with missing objects at certain height!
Mon, Mar 2, 2009 at 10:18:02 PM | Section View with missing objects at certain height!
flynakashima
Hi,
 im having a problem with section view in revit architecture 09, the section only showing some detail at certain level, but some objects and details were missing if im pulling the crop region higher. ive checked the VG, view templates etc but seems there is no setting with such thing. hope you guys can help to sort this out. thanks.
Tue, Mar 3, 2009 at 6:57:40 AM | Section View with missing objects at certain height!
3.5 Stars: 391 Votes
Sorry but your question is not clear.  What is the difference between these two views?  I see doors in one but not the othere.  Is that what you are talking about?  Are these the same section?  Is everything in this file or linked?
Tue, Mar 3, 2009 at 8:47:56 PM | Section View with missing objects at certain height!
flynakashima
that is the problem, its missing if i move the crop region (crop view) higher. ie: details and component show up at +- 1000mm, if i pull the region higher > +-1000mm it will not showing the detail in section. any solution?
Wed, Mar 4, 2009 at 4:47:40 AM | Section View with missing objects at certain height!
tim123
4 Stars: 19 Votes
Does this happen if you create a similar section?  Does it still happen if you increase the view depth?
Wed, Mar 4, 2009 at 6:38:32 PM | Section View with missing objects at certain height!
flynakashima
yup still, tried the project transfer method from default template to replace the section properties, but still the same, i assume the project properties had been changed, but i cant found the solution.
any help?
Thu, Mar 5, 2009 at 3:43:40 AM | Section View with missing objects at certain height!
tim123
4 Stars: 19 Votes
Does it happen to any of the other sections in your project, or only this one?
Tue, Mar 10, 2009 at 10:01:07 PM | Section View with missing objects at certain height!
flynakashima
yup, it does happen to any sections. still ive no idea how to solve this problem
Tue, Mar 10, 2009 at 10:14:02 PM | Section View with missing objects at certain height!
hjacobs
admin
hjacobs Avatar
3.5 Stars: 16 Votes
So, you don't make any changes to the view properties except drag the crop region up?  That sounds like there's something wrong with your file...
Hiroshi Jacobs
Tue, Mar 10, 2009 at 10:41:04 PM | Section View with missing objects at certain height!
flynakashima
yup exactly, something wrong with the file. :/
Missing Objects in Section View
Wed, Jan 14, 2009 at 9:28:23 AM
Can I have objects in a parametric array change height?
Fri, Sep 3, 2010 at 3:06:21 AM
Missing objects in section view (????)
Thu, Mar 25, 2010 at 8:45:54 AM
Section tag missing on plan but section still exists
Tue, Nov 22, 2016 at 2:58:15 PM
Section callout missing
Mon, Dec 16, 2013 at 4:00:09 PM
Page generation time: 0.9713
