77 Users Online (76 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Community >> Newbies >> Hand-drawn effect
Thu, Feb 19, 2009 at 1:28:02 PM | Hand-drawn effect
SemiDeatched
Does Revit support Squiggle-like effect?
 i.e. softer edges for presentations?
Thu, Feb 19, 2009 at 1:32:28 PM | Hand-drawn effect
4 Stars: 201 Votes
This is not Photoshop or Rhino but, Like what???
Thu, Feb 19, 2009 at 1:37:14 PM | Hand-drawn effect
SemiDeatched
Squiggle is a gadget that post processes Autocad to make lines and edges less distinct to give that old world, like ma used to make, hand drawn look.
 After a bit of googling... I found that export to DWG and use Sketchup might be a solution. (albeit it long winded).
Thu, Feb 19, 2009 at 1:48:57 PM | Hand-drawn effect
4 Stars: 201 Votes
Like "Napkin Sketch" in Autocad???? NO....
Tue, Feb 24, 2009 at 8:37:06 AM | Hand-drawn effect
vanzoeren
vanzoeren Avatar
I was going to say, Revit doesn't do that sort of thing. For that hand-drawn effect, sketchup is the way to go. Or you could actually hand draw it, but who does that any more Puh
vanzoeren - I live to learn, and learn to live
Tue, Feb 24, 2009 at 9:02:04 AM | Hand-drawn effect
broncos4life
4 Stars: 10 Votes
Actually I belive there is a way to get SketchBook Pro into Revit.  I would try that program.  The program is very powerful for sketches.
Tue, Feb 24, 2009 at 1:23:06 PM | Hand-drawn effect
LIZARD2806
3.5 Stars: 7 Votes
I use a free* program called Impression.  It's pretty good and is put out by Autodesk.  If you log in to your subscription center it should be available in the downloads area.  Crying *with subscription).  I am by NO MEANS an expert (I have only spent a few hours playing with it-but it has promise), but below is a sample of what it can do after said experience.
Edited on: Tue, Feb 24, 2009 at 1:25:54 PM
Thu, Jun 19, 2014 at 12:27:39 PM | Hand-drawn effect
MacRowerGT
MacRowerGT Avatar
2 Stars: 2 Votes
Use Sketchbook Designer then export to DWG, then import to Revit
Utilizing Revit Building Suite 2014
Thu, Jun 19, 2014 at 12:30:00 PM | Hand-drawn effect
3.5 Stars: 395 Votes
MacRowerGT,
No need anmore for another program.  I've not used it yet but 2015 has hand drawn lines.
Create Revit from Hand Drawn As-builts
Mon, Jun 4, 2012 at 9:10:14 AM
Revit and the hand drawn look [ 1 2 ]
Fri, Nov 21, 2008 at 9:28:41 AM
16
can't add hand rail
Thu, Feb 26, 2009 at 6:35:39 PM
Right/Left-hand doors
Fri, May 10, 2019 at 9:32:40 AM
Flip hand of base molding
Thu, Oct 16, 2014 at 10:42:37 AM
Page generation time: 0.3443
