83 Users Online (81 Members):
Forums >> Revit Building >> Technical Support >> Rendering the Wrong Material
69 Posts No Rating |
We have several custom made families that are nested into other families that are put into our projects. We originally made some of them to render a certain color for schematic designs. As we move into DD, we need to assign realistic colors and materials. Several times, I've changed the material to be the right material and reloaded the families into the proper projects/host families and the component will still render the wrong color. Any help?
I'd also like to add, if I load the component into a brand new project, it will render the correct color and material.
The project controls the material settings.... it will always over-ride what is set in the family. So - just identify what materials are used and change their settings in the project to match what they are set at in the family. This is not a problem .... it is an advantage. Every project can use the same family but change the material to suit the project.
I've re-checked the project materials and they are correct. The object still renders the wrong color. We are also linking the project into another project (site plan).
Rendering Problem. |
Wed, Apr 9, 2008 at 5:10:57 PM
Need help with rendering! |
Mon, Mar 3, 2008 at 10:17:43 AM
Rendering Material Accuracy |
Thu, Mar 12, 2009 at 5:11:01 AM
Wall material is all grey in rendering |
Wed, Oct 29, 2008 at 4:49:43 PM
Revit rendering is not showing the right floor material |
Tue, Feb 10, 2015 at 1:08:32 PM
Members: | 1999278 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
