72 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Roof types
Thu, Feb 12, 2009 at 6:41:30 PM | Roof types
jnordby
I am looking for a Grass "Palapa" style roofs for my clients projects in mexico? Where can I get this??ANYONE KNOW????
Thu, Feb 12, 2009 at 7:27:59 PM | Roof types
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi jnordby. Are you looking for something like this (see image)? if so, check here: http://www.cgtextures.com/ , roofing--thatched
Edited on: Thu, Feb 12, 2009 at 7:30:50 PM
Thu, Feb 12, 2009 at 8:29:06 PM | Roof types
jnordby
Erland73,
Thank you for your rely. I am new to revit and how do I use these images???
Jnordby
Thu, Feb 12, 2009 at 10:38:37 PM | Roof types
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Hi jnordby, so welcome to this world. Ok, I'll try to explain the easiest way to do this, for you:
1-Create your roof and duplicate it with the name you want (i.e. Palapa roof).
2-Go to Settings then Materials...and duplicate the "Default Roof" material and give it the name you want (i.e. "Palapa Roof" ) .
3-Go to Render Appearance in Generic Material Properties then in Color choose Image file.
4-Search the path where you have the image downloaded from the link I gave you before (in this case i didn't use a bump image).
5-Give the image the scale and the brightness you like more and then click OK.
6-Select your Palapa roof and go to Element Properties button and then click Edit/new... button
7-In the Structure Parameters click Edit... then in Materials select the material you previously created and click OK to all
8-Render
Hope it helps you.... (This is in case you have Revit Architecture 2009)
Edited on: Thu, Feb 12, 2009 at 10:39:02 PM
Fri, Feb 13, 2009 at 10:47:19 AM | Roof types
jnordby
Ok I get lost half way through... adding the pattern into the new roof I created.....HELPPPPPPPPPPPPPPPP
Fri, Feb 13, 2009 at 10:54:20 AM | Roof types
4 Stars: 202 Votes
What's the problem???? I think Erlander's explanation it's OK!
Fri, Feb 13, 2009 at 11:00:06 AM | Roof types
erland73
erland73 Avatar
4.5 Stars: 85 Votes
OK jnordby, what is the part you don't "catch" yet??
Mon, May 21, 2018 at 4:01:31 AM | Roof types
Buyaman
Hello guys
just don a normal roof and change the material to 'Bocote'. looks fine when rendered.
hope this has helped
Roof Types: How to change them
Thu, Oct 25, 2012 at 9:04:34 AM
Roof Thread
Sat, May 20, 2006 at 8:25:57 AM
Family types - conditional statement
Mon, Apr 18, 2011 at 3:59:50 PM
Changing line types and styles in cross section views, wall types etc...
Wed, Apr 12, 2006 at 12:52:32 AM
Section types
Tue, May 9, 2006 at 12:45:52 PM
Page generation time: 0.9448
