66 Users Online (65 Members):
Forums >> Community >> The Studio >> Wall type
3 Posts No Rating |
Can we create a line type in lieu of hatch pattern inside the wall? Say we want a one hour rating with a #4 lineweight in 'dash' linetype or 'double dash' if 2-hr rating.
Don't think so. Probably the best way to do the fire-rated wall annotation is to create Detail lines and lock them to the CL of the walls.
3 Posts No Rating |
Thank qthdad. That is what we actually doing right now. The only thing is we need to copy/ paste it in all other plans (e.g. ceiling, finish, equipment etc)...or there is other way to do that?
YES___you can do so, but only :: View specific. T O|D O: In your desired View, select your 'rated' Wall Type> right-click...Select All Instances > right-click again...Override Graphics in View > By Element... > Drop-down 'Cut lines' and establish your desired line Weight, Color, & Pattern. VIOLA
Edited on: Thu, Feb 12, 2009 at 3:23:33 PM
P A R A M E T R I C components
http://www.parametriccomponents.com [open source Revit Content]
http://www.revitcomponents.blogspot.com [blogging for Revit Components] |
9 Posts No Rating |
Anyother way to do so is to create a hatch pattern and to assign a specific hatch for each rated wall condition. You can do this through the materials libary and have a wood stud material for each of the rated types that you use.
Wall Thickness in Type Parameter |
Fri, Jun 1, 2018 at 7:39:15 AM
Wall Sweep vs. Wall Type |
Mon, Mar 7, 2016 at 10:36:59 AM
parametric window should recognize wall type! |
Wed, Apr 12, 2006 at 7:44:20 AM
Customizing wall type properties |
Mon, Oct 31, 2011 at 7:55:30 AM
Brick will not wrap to new wall type |
Thu, Apr 28, 2011 at 10:18:56 AM
Members: | 1998887 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
