102 Users Online (101 Members):
Forums >> Revit Building >> Technical Support >> parameter-label
79 Posts No Rating |
Does anyone have, or know how to create a parameter that lists a sheet # of #? Like, "sheet 1 of 15" and so on.
i'm using revit '09.
Unfortunately there is no default parameter that will achieve this effect. however using a shared parameter you could set up a manually updated parameter to host the "of" value of sheets. To do this you will need to use a shared parameter in the Titleblock Family. Please post your experience and confortability level within the Revit Family Editor. I will post further details depending on your experience level.
Yes, there is a way__fake em'in! T O|D O Create a Drawing Sheet Project Parameter (Instance of Course) - Settings > Project Parameters... > Add... > Name # of #_Common_Text_choose the desired Group_Instance_select Category 'Drawing Sheet'__OK
- Navigate to the 'Drawing List' (to create one > View_New...Drawing List...) > Enter into its View Properties > Fields<Edit...>_add the # of # parameter__OK
- Fill in the cells while in'Edit Schedule' mode
<3 and <3
P A R A M E T R I C components
http://www.parametriccomponents.com [open source Revit Content]
http://www.revitcomponents.blogspot.com [blogging for Revit Components] |
Blank line in text label |
Fri, Sep 16, 2011 at 4:07:46 PM
label parameter formula |
Thu, Apr 26, 2012 at 12:15:03 PM
Instance Parameter to control another Instance Parameter |
Thu, Jul 22, 2010 at 6:22:48 AM
Using View Name as Label Parameter. |
Mon, Apr 29, 2013 at 7:48:49 AM
Label location flexible |
Thu, Oct 13, 2011 at 4:42:22 AM
Members: | 1999266 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
