84 Users Online (83 Members):
Forums >> Revit Building >> Technical Support >> Stud Wall-Make finishes disappear
79 Posts No Rating |
Is it possible to hide gyp board finishes on a stud wall in plan without going through and using the linework tool to make it an invisible line, or drawing a stud wall then seperate gyp board walls attached? This seems like it should be an easy fix, but thus far I have found no easy solutions. Thanks for any help.
Without setting graphics to course?
Yes__Changing the "Detail Level" to the "Course" setting will apply a Course Scale Fill Pattern to your Wall 'Type'. To alter the Course Fill navigate to your Wall's Type parameters__Graphics
P A R A M E T R I C components
http://www.parametriccomponents.com [open source Revit Content]
http://www.revitcomponents.blogspot.com [blogging for Revit Components] |
setting graphics to coarse simply shows the entire wall width without showing the lines where the outside of the studs would be. I want to see the outside lines where the studs would lie, without seeing the lines of gyp board. i have a 3 5/8" stud wall with gyp on either side which makes for a total wall width of 4 7/8". I want to see the 3 5/8" width without the lines for gyp. thanks.
----------------------------------- HuntFlo |
YES__ Got it! - Navigate to the "Visibility Graphics" [VG]
- Click the "Object Styles" button towards the bottom of the VG window.
- In the Object Styles window, drop down the 'Walls' Category/
- Change the"Walls_Line Color" to White.
VIOLA *please find attached...where the effect has been Applied
Compound Walls & Finishes stopping at specific Heights |
Wed, Nov 8, 2006 at 4:22:10 PM
Stud wall family help PLEASE.... |
Fri, May 9, 2008 at 1:09:58 PM
Wall Finishes |
Fri, Dec 20, 2013 at 2:26:15 PM
Internal Wall Finishes |
Tue, Mar 25, 2014 at 4:18:18 PM
Creating a wall finishes schedule, and coding wall finishes on elevations |
Fri, Jun 1, 2012 at 4:06:32 PM
Members: | 1999278 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
