161 Users Online (159 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Tips & Tricks >> PASTING IN THE SAME PLACE w/Ctrl+C_Ctrl+V
Tue, Jan 27, 2009 at 3:27:58 PM | PASTING IN THE SAME PLACE w/Ctrl+C_Ctrl+V
RevitComponents
RevitComponents Avatar
4 Stars: 22 Votes
Draw >>
When I desire to copy something in the same place_ I do...
**Make sure that I am copying the selection in the same view that I want to paste
  1. Select object(s)
  2. <Ctrl+C>
  3. <Ctrl+V>
  4. <0> (zero)
  5. <enter/return>
 VIOLA Smile
 How about you?
Edited on: Tue, Jan 27, 2009 at 3:30:45 PM
Edited on: Tue, Jan 27, 2009 at 3:31:33 PM
P A R A M E T R I C components
http://www.parametriccomponents.com [open source Revit Content]
http://www.revitcomponents.blogspot.com [blogging for Revit Components]
Tue, Jan 27, 2009 at 7:07:28 PM | PASTING IN THE SAME PLACE w/Ctrl+C_Ctrl+V
Sven
3.5 Stars: 3 Votes
Great tip! These sweert shortcuts are like looking in the back of the fridge to find some beer you forgot you bought - score!
Wed, Jan 28, 2009 at 8:32:23 PM | PASTING IN THE SAME PLACE w/Ctrl+C_Ctrl+V
emgeeo
3.5 Stars: 7 Votes
I was having a bad day until...
thanks!
Fri, Jan 30, 2009 at 9:07:51 AM | PASTING IN THE SAME PLACE w/Ctrl+C_Ctrl+V
JRMello
Okay, cool. But my issue is why didn't they make this work when pasting to another view? What do you guys use it for if you're pasting the same thing in the same spot in the same view? Hm.
Fri, Jan 30, 2009 at 10:29:15 AM | PASTING IN THE SAME PLACE w/Ctrl+C_Ctrl+V
RevitComponents
4 Stars: 22 Votes
Yes__A 'paste in the same place' is desired to do various tasks:
LINEWORK_
  1. Extrusion_for drawing identical linework on different reference planes/lines.
  2. Blend_my fav, match the base linework with the top; viceversa... mathing one blend form with the another.
  3. Sweep_same paths... same profiles, different reference planes.
OBJECTS_
  1. Sometimes you want to copy something and attach it to another Reference Plane, and in order to do so you either remove the "Contstrants" or "Disjoin" >>but if you 'copy in same place' by using the "Zero" technique you can then alter the referencing plane without having to remove certain parametric properties i.e. having to re-draw the object to behave accordingly.
  2. To Reference other objects in space.
  3. Smile
Fri, Jan 30, 2009 at 12:37:29 PM | PASTING IN THE SAME PLACE w/Ctrl+C_Ctrl+V
JRMello
Ok, I feel a bit enlightened. Good examples. I'm going to make "work plane, work plane, work plane" my mantra.
Thu, Jan 7, 2010 at 11:02:05 AM | PASTING IN THE SAME PLACE w/Ctrl+C_Ctrl+V
pdoug
1 Stars: 1 Votes
Is there a quick way to paste in the same place from one view to another?  This tip only works in the same view - as noted.  Thanks-
Thu, Jan 7, 2010 at 12:13:46 PM | PASTING IN THE SAME PLACE w/Ctrl+C_Ctrl+V
TKennedy
4 Stars: 7 Votes
Yes you can paste to the same place in a different view. <Ctrl+C> to copy to the clipboard, then open the view you want to paste into and use the Paste Aligned|Current View tool (I set the shortcut to be PS). In 2010 it's on the Modify tab, Clipboard panel. I forget where it is in '09.
The Paste Aligned|Select Views/Levels tool is also very handy when you need the same thing in a number of different views.
Thu, Jan 7, 2010 at 12:42:47 PM | PASTING IN THE SAME PLACE w/Ctrl+C_Ctrl+V
3.5 Stars: 391 Votes
I would like to add that you can use the ctrl c / ctrl v in places where the right click copy/paste is not available.    For instance values in family parameters - formulas ...pasting text in the middle or anywhere in a text note.
Thu, Jul 23, 2015 at 12:01:04 PM | PASTING IN THE SAME PLACE w/Ctrl+C_Ctrl+V
markheaviland
Thank you for this information.  I just added my keyboard shortcut (view panel / user interface / keyboard shortcuts) for "paste aligned to current veiw" as ctrl + shift + alt + V.  So awesome!
Sat, Feb 13, 2016 at 12:25:57 AM | PASTING IN THE SAME PLACE w/Ctrl+C_Ctrl+V
simon1688
Here is a work around group the items you want to copy and paste go to the view you want to paste in, the preview will come up move your cursor over the preview and now you can snap to exact same preview spot.
Edited on: Sat, Mar 5, 2016 at 3:39:02 AM
Revit 2014 user
Mon, Mar 28, 2016 at 11:32:04 AM | PASTING IN THE SAME PLACE w/Ctrl+C_Ctrl+V
roms504
Thanks Guys,
I dont know why I never thought about adding my own shorcuts before hand. The Paste in Current view shortcut is a big help. Though the one suggested seems a bit long. Whenever a shorcut has more than three keys its probably easier for me to just click Smile.
using contol or option keys when setting hot keys?
Mon, May 18, 2009 at 4:47:26 AM
Copy and Paste
Mon, Dec 13, 2010 at 8:06:14 AM
Copy and paste issues
Thu, Jun 5, 2008 at 7:31:17 AM
Revit crashes whenever I hit CTRL + Tilde key
Tue, Dec 7, 2010 at 7:19:36 PM
Importing General Notes
Wed, May 5, 2010 at 1:26:49 PM
Page generation time: 1.7983
