61 Users Online (60 Members):
Forums >> Revit Building >> Technical Support >> Line between different wall types in eleveation
78 Posts No Rating |
There is a line that revit created between two different wall types in my elevation, as shown in the attached JPEG. One wall is an 8" stucco wall and the other is a 12" concrete wall with the same finish as the 8" stucco. I have tried joining the walls but that didn't work. Any ideas on how to make the wall look smooth, without these lines?
35 Posts No Rating |
Make sure that your wall surfaces are aligned properly, failing that use the linework tool (top left of your screen beside the match properties & tape measure icons). Set the line work to invisible lines and then select the offending lines
That did it, thanks for the help
Changing line types and styles in cross section views, wall types etc... |
Wed, Apr 12, 2006 at 12:52:32 AM
LINE BETWEEN DIFFERENT WALL TYPES |
Tue, Jun 17, 2008 at 4:29:50 AM
Purging Line-Types |
Tue, Dec 12, 2006 at 6:41:21 AM
Wall line thicknesses |
Mon, Jul 24, 2006 at 6:04:14 AM
How do I make custom wall types publicly accessible? |
Sun, Apr 4, 2010 at 2:17:08 PM
Members: | 2056134 | Objects: | 23069 | Forum Posts: | 152281 | Job Listings: | 3 |
