73 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> Roof - adding smaller gable to dutch hip.
126 Posts No Rating |
Hello, Using Revit 2008. I figured out how to create the dutch hip by reading a couple post. Now I am not sure how to go about adding the smaller gable to the roof. See attached. Any suggestions. Thanks, Raina Mc
Your example should be quite easy to create, as it appears to project slightly from the roof face. Create short projecting lines that define slope with the gable part being non slope defining - see image
I have two roofs with the bottom hip set to a cut off level and the top gable offset. So it does not work unless I am still doing something wrong. I am trying to add another roof to see if that will create that gable up front.
Ended up creating 3 seperate roofs. It works but it seems like there would be a better way. Thanks,
"Dutch Gable" roof |
Mon, Mar 31, 2008 at 1:35:54 PM
dutch gable in roof |
Tue, May 29, 2007 at 11:28:04 PM
Dutch Gable Roofs |
Tue, May 19, 2009 at 12:35:08 PM
Can't get Gable roof to Join Hip roof |
Wed, Aug 20, 2014 at 3:56:33 PM
Roof Styles |
Thu, Nov 2, 2006 at 9:33:46 AM
Members: | 1993420 | Objects: | 22881 | Forum Posts: | 152185 | Job Listings: | 3 |
