Forums >> Revit Building >> Technical Support >> scaling text and dimension according to the scale of view
27 Posts No Rating |
i am facing a problem of text heights and dimension heights ..every time i change the scale of the view port according to the sheet size, i have to again change the text heights..Is there anyway by which i can fix the text height according to the scales..same is the problem with room tags, wall tags and door tags...
Did you try to print some of these views in differents scales and see if the height text is fine? Because Revit, adjust the height text autom. by the scale you put in the view, no matter if you print the same Sheet in a different scales, the heigh of the text is allways the same....
you should be able to find a lot of info posted in the form on this subject. if none of this posted info helps let us know.
thats wat ,,the text size remains same in all scales....i want it differrent in different scales....(If i give a text height of 2mm in 100 scale its the same in 50 scale also ..i want it to be 4mm in 50 scale...and so on ...)
"thats wat ,,the text size remains same in all scales....i want it differrent in different scales....(If i give a text height of 2mm in 100 scale its the same in 50 scale also ..i want it to be 4mm in 50 scale...and so on ...)" if the text is placed in a view. what you are asking for is exactly what's going to happen when you change the scale of the view.
Edited on: Fri, Aug 29, 2008 at 10:31:55 AM
98 Posts No Rating |
So what coreed is getting at is that if you place your text on the sheet rather than in the view you'll get the result you're after. Model text will behave that way as well (but then you have text floating around in your model which is annoying).
Sorry, nix the part about the sheet. (the model text is right though)
How do you handle dimensioning not-to-scale stuff in Revit? |
Mon, Aug 15, 2011 at 2:30:05 PM
Scaling of text, dimensions, and wall textures question. |
Wed, Jan 16, 2008 at 11:41:32 AM
View Title scale text won't show |
Tue, Dec 29, 2009 at 2:36:51 PM
Scaling Down |
Thu, Apr 29, 2004 at 8:57:07 AM
Dimension Text [ 1 2 ] |
Tue, Jul 8, 2008 at 9:15:07 AM
18
Members: | 2000472 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
