105 Users Online (104 Members):
Forums >> Revit Building >> Technical Support >> shaft openings in linked RVT files
4 Posts No Rating |
here's a quick question, i'm working on a a core and shell project. the core and shell architect has their file and i have mine with the tenant improvement file. i'm trying to get my stair shafts to visibly cut through the floor plates shown in the core and shell file. the shafts are in my file, but the linked floorplates don't show the cuts. what options do i have? thanks in adv. alex
The "Shaft opening" only cut through the floor plates of other Revit linked file if you pick in that Linked file and in the Options Bar you pick in "BIND" and pick OK, don't pick in "Remove Link" if you want to keep the other file link to the other (the file you create with the Shaft opening)...
Edited on: Wed, Aug 27, 2008 at 4:17:01 PM
Copy Monitor Shaft Openings |
Thu, Oct 21, 2010 at 8:16:14 PM
A Floor That Can't Be Penetrated by Shaft Opening |
Thu, Feb 20, 2014 at 2:30:48 PM
Deleting Linked RVT Categories |
Fri, Feb 3, 2006 at 9:40:29 AM
Visibility of Shaft Openings in a detail view |
Fri, Apr 17, 2009 at 11:13:42 AM
Linked rvt into another rvt |
Tue, Jan 20, 2009 at 12:21:13 PM
Members: | 2001100 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
