68 Users Online (67 Members):
Forums >> Revit Building >> Technical Support >> True elevation for curved curtain wall
Hi, Can someone guide me on how to get the true elevation for curved curtain wall? See attached snapshot. Thnaks in advance Ramesh
Now on the implementation stage.... |
You probably don't mean true elevation because that's obvious. If you want to "unroll" your elevation, the only thing you can do is to create an elevation normal to each flat segment and place them side by side. Since this is not normal, you could also do as you would have in CAD and just draw it as line work.
Yeah it seems to be only workaround for this. Thnaks HUB
Modelling a curved curtain wall |
Thu, Aug 25, 2011 at 7:18:35 AM
curved angled curtain walling |
Wed, Mar 8, 2006 at 4:18:50 AM
curved curtain wall, straight transoms, curved panels |
Tue, May 12, 2015 at 8:36:03 PM
curved curtain system -diagonal grid system? |
Wed, Feb 11, 2009 at 4:24:47 PM
Projected Curved Elevation (How to flatten a curved wall in elevation view) |
Fri, Feb 11, 2011 at 11:55:48 AM
Members: | 2023313 | Objects: | 22982 | Forum Posts: | 152198 | Job Listings: | 3 |
