Forums >> Revit Building >> Technical Support >> WALL JOIN PROBLEM - Ends showing in 3D and Elevation View
5 Posts No Rating |
Hi all, When im joining walls that were not draw in one go, the wall ends keep showing up in 3d and elevation views. In plan it doesn't matter, the join is seen as a mitred join, but when one of the walls in the join is selected (turning it red) you can see the wall end not mitring - which is showing in 3d and elevation. Hopefully the pictures attached will make it clearer. Thanks
5 Posts No Rating |
Sorry i forgot, im using Revit Architecture 2008
Hi, make a trim between the 2 walls and "Join Geometry" and "Edit Wall Joins"...
5 Posts No Rating |
Do I need to pull the walls apart before that, ie break the join? Ive tried both ways, if I dont pull the walls appart it wont let me trim them together but when I do pull them apart, trim, and then try and join geometry it gives an error that "Highlighted elements are joined but do not intersect." Ive then tried to unjoin them but nothing happens!
Hi, i go put here a video, wait a moment..
Here is the video: http://screencast.com/t/VF1nPX7rnib Give me a feedback, ok?
5 Posts No Rating |
I seem to have got around the problem with that, thank you. I can see a mitred join on top of the wall which is slightly annoying but it won't show when the roof is on. Thanks.
You Welcome...
Grade Lines in Elevation view not showing |
Fri, May 25, 2007 at 5:49:36 PM
Need Help Joining Rafter Ends in Revit Architecture 2009 |
Fri, Apr 10, 2009 at 11:09:57 AM
Wall Joins at ends of uneven width walls |
Tue, Sep 18, 2007 at 2:00:21 PM
View Name showing up in Elevation Tag |
Wed, Feb 29, 2012 at 6:53:36 PM
Lines from different wall types showing up in elevation |
Tue, Sep 24, 2013 at 10:07:46 PM
Members: | 1998395 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
