48 Users Online (47 Members):
Forums >> Revit Building >> Technical Support >> Wall attached to Ramp
7 Posts No Rating |
Im trying to attach the base of a wall to a ramp. This wall actually sits on the ramp as the ramp slopes up and curves. Please see the example file. Our client is staying on Revit 2008 so the solution needs to work in 2008.Any thoughts on modeling it better then it is now(notice gaps at end of ramp) would be great.Thanks,~Scott
try this: go to a section view. Select wall>select attach top/base> select base in options bar>click ramp does this work for you?
3 Posts No Rating |
draw a reference plane aligned with the ramp slope. Then attach base of wall to ref plane.
Spiral wall along ramp |
Fri, Jul 11, 2008 at 2:42:59 PM
A ramp! |
Thu, Jan 21, 2016 at 11:37:45 AM
RAMP TAG FAMILY FOR RAMP NAME |
Mon, May 9, 2016 at 6:49:09 AM
Ramp and Topo surface problem Revit 2014 |
Thu, Oct 9, 2014 at 8:36:16 PM
Flat Railing with a ramp as a host |
Mon, Dec 27, 2010 at 6:27:11 PM
Members: | 2005725 | Objects: | 22910 | Forum Posts: | 152183 | Job Listings: | 3 |
