Forums >> Revit Structure >> Technical Support >> making beams dotted and upstands
7 Posts No Rating |
hi guys, useing 2008, i have beams that are going from top of slab down and past, however because they are going down i need them dotted, but i carnt find a function to do that, is there a way? also how dp i create upstands, i only seem to be able to draw beams going downwards. cheers
Do you have an image of the issue you are having. You're saying beams so I'm thinking horizontal elements, but you're talking about them as if they are vertical, so I can't really visualize what the issue is here.
You fell victim to one of the classic blunders. The most famous is never get involved in a land war in asia, but only slightly less well known is this! Never go in against a Sicilian when death is on the line! |
7 Posts No Rating |
ill attach an image to this post. they are horizontal beams, and say 350dp x 1000wide so they are going from the top of slab, downwards. Edited on: Mon, Jun 2, 2008 at 8:41:37 AM
Edited on: Mon, Jun 2, 2008 at 8:43:44 AM
Gotcha. Sorry for the misunderstanding. Take a look at Settings > Object Styles and play around with the hidden line style under structural beams. See if that helps for the line types, althought I'm not expecting it to. You may need to use the line works tool to accomplish what you are wanting to do. If you figure something else out, please let us know. As far as creating a beam that goe up, you can do 1 of 2 things: 1) Just reposition the beam so that it is above the slab instead of below. 2) Create a new beam profile family that places the profile above the Top/Bottom reference plane instead of below the Top/Bottom Reference plane. If you look at the profiles used for the beams in the beam families, you will see what I am saying. HTH, let me know if you have any questions baout this.
Select your reference level, say the top of plate and at "Start and End offset level" you can add the depth of beam to give it an upstand.
Motto: "No Post left behind" |
7 Posts No Rating |
that changing the refrence has worked a treat cheers guys
7 Posts No Rating |
sorry, also whats the line works tool?
7 Posts No Rating |
that has worked, excellent that is so good now. onyl other thing is having the line on the join of the 350slab thckining and 350dp beam, but i doubt there is a way round that one tbh
Exposed beams help? |
Mon, Dec 19, 2011 at 4:29:57 PM
Wooden Beams, beams beams. |
Wed, Jul 15, 2009 at 12:20:06 PM
quick question on legend |
Wed, Dec 11, 2013 at 1:21:24 AM
pasting aligned. |
Thu, Apr 2, 2015 at 6:10:33 PM
joining two beams |
Fri, Jul 6, 2007 at 12:03:10 PM
Members: | 2000436 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
