128 Users Online (127 Members):
Forums >> Community >> The Studio >> Revit VS. ADT2005
7 Posts No Rating |
Hallo, I am an architect from Czech republic and have a problem...
I am very good in acad, thats 2d. And now I am thinking about 3d. A know 3ds max very well. Can anybody help me, wheather to choose adt2005(2006) or Revit7 (.
I understand designing and engineerig and when I am plannig i need to solve the details aswell.
I do new things and rebuilding 50:50
Thanx
Post edited on 2005-04-04 06:25:34
Post edited on 2005-04-04 06:25:52
Post edited on 2005-04-04 07:39:35
Post edited on 2005-04-04 09:29:00
22 Posts No Rating |
VonVan,
Let me explain my background. I work for a local reseller in Colorado. That stated let me say that there are pluses and minused to both software. I have ppl who love Revit and other who swear by ADT. Personally I have come from the background of AutoCAD also and my thought is Revit (although most think with an ACAD background it should be ADT). I like the interface better and the fact that it is bidirectional which ADT is not. Although Autodesk has had ADT longer and worked on it more so there are a more features in it then Revit. That aside Autodesk is full blown into Revit and are developing it fast. Some parts of it are ahead of ADT others lag behind but I think in release 9 or 10 it will exceed ADT, but of cource that is just my opinion. Since you are here I would assume something in Revit caught your attention. You may try the 30 day trial download from Autodesk.com to see more of it. Dont want to take up to much space.
Mack
19 Posts No Rating |
Hello
I am an Architectural Draftperson in Sydney & I have been trained & used; ADT Revit & used AutoCAD from R11, initally ADT is my first though due to commands similar & using autocad background but Autodesk will be fazing out ADT, Autocad to push REVIT,
Revit is smarter & pretty, but there is a cost- Hard ware min Igb RAM fast CPU for rendereing, dual screens for working in plan & viewing in 3d.
I am using Revit not with acad 2005.
I just completed a dual occupancy (two homes attached up to presintation & council lodgement), the Revit file is currentlly 27.5mb with 4 backups the same size.
it took me a little while to get my head around Revit, (depends on person)
I like Revit alot, when using acad I miss the smart features Revit has.
Revit has alot to grow & has only just started, Acad is over 20years old in softwar terms thats old.
Revit can be costomised to use short cuts on key board.
if I had to choose now that I am ok with Revit I will use Revit.
hope this helps.
Chris
10 Posts No Rating |
in simple words i tell u go directly to revit,
none of the 2 softwares is oerfect, but to learn or achieve anyrhing in adt2005 u must fight, while in revit it's easier, more smart.
but becareful that revit seducts.
u still need advice even if u think it so simple
Upgrading versions of Revit |
Mon, Oct 1, 2007 at 11:40:11 AM
Revit Problem Access Denied |
Thu, May 6, 2004 at 2:04:14 PM
Revit for Construction Documents [ 1 2 ] |
Tue, Jan 24, 2012 at 10:57:38 AM
20
4D simulation in Revit? [ 1 2 ] |
Mon, Jan 17, 2011 at 11:27:39 AM
18
I need to open a Revit 2011 file into the Revit 2009 ? Are there any way ? [ 1 2 ] |
Thu, Jan 6, 2011 at 3:25:02 PM
18
Members: | 2000897 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
