57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Joining the Geometry of two floors
Tue, May 13, 2008 at 5:55:42 AM | Joining the Geometry of two floors
farbdias
Hello.
I have two concrete floors beside one another.
One of the floors drops down 150mm.
How can i join the geometry of these two floors to make them realistic like the actual refabrictaed concrete slab that will be used.
Many thanks.
Ian
Wed, May 14, 2008 at 5:46:12 AM | Joining the Geometry of two floors
dianajohn
The simple answer is to use the 'Join Geometry' function on the Toolbar this will join entities of the same material. By adding a edge beam to one slab you may get a better finish
Best of Luck
John A
roofs - extra geometry after joining
Thu, Jun 25, 2015 at 10:56:03 PM
highrise towers slabs-walls joining
Tue, Jun 1, 2004 at 6:18:09 PM
Joining 2 objects with "Join Geometry" Tool
Fri, Sep 5, 2008 at 4:10:05 AM
BEAMS JOINING COLUMNS problem
Tue, Jun 30, 2015 at 7:41:51 AM
Joining beams to walls and floors
Thu, Jan 15, 2009 at 9:00:36 AM
Page generation time: 0.6994
