36 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dimensioning Curved Walls
Fri, Apr 25, 2008 at 10:29:14 AM | Dimensioning Curved Walls
clinard
See attached image. How do I get Revit to do this??
Thu, May 1, 2008 at 1:57:09 PM | Dimensioning Curved Walls
LIZARD2806
3.5 Stars: 7 Votes
Select Dimension from the Design Bar, then on the Options Bar, select the Arc Length button (should be the last button before the word "Prefer:" ).  Now select the wall arc you want to measure, then the from point, to point and finally the location of the dimension.  NOTE:  you may have to use the TAB key to cycle through to the point you want to pick
Edited on: Thu, May 1, 2008 at 1:58:03 PM
Dimensioning an Ellipse?
Thu, Apr 24, 2008 at 12:16:07 PM
Dimensioning Angular Walls
Mon, Jan 16, 2006 at 6:34:07 PM
curved curtian walls
Mon, Nov 13, 2006 at 6:19:28 AM
curved surface
Tue, Nov 6, 2018 at 7:03:42 AM
dimensioning a curved wall's faces in section?
Sun, Jan 17, 2016 at 6:59:30 AM
Page generation time: 0.9016
