95 Users Online (93 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Community >> Newbies >> Roof joins for split level house
Mon, Apr 7, 2008 at 12:12:35 AM | Roof joins for split level house
Herbo76
Hi,
I know this has probably been outlined before but I was wondering if anyone could give me some guidance as to joining 2 hip roofs which are at differing levels the (1st floor is 950mm above the ground level).  I have tried a series of different methods as outlined in the tutorials but just can't seem to get the ground floor roof to join in at the higher roof correctly.  I have attached the layout that the roof is supposed to take.  I can't get the roof plane at the circled area to designate a pitch.  All the other planes work and it is this plane only where the valley comes into the wall which seems to be creating problems.  Could someone give me an idea of how to create the 2 roof joins properly.
Thanks
Chris H
Wed, Apr 9, 2008 at 7:32:37 PM | Roof joins for split level house
Herbo76
After great effort I finally got the roof to work.  The only thing wrong with it is one of the valley lines on the upper roof section has continued through to the hip line.  Does anyone know of a way to clean this up easily?  See the 3d image I have attached
Chris HBrisbane, Australia
How do you treat split levels or minor level changes?
Mon, Jun 26, 2006 at 10:40:02 PM
Roof joins
Fri, Jul 29, 2005 at 6:47:04 PM
How i can repair my house roof?
Fri, Sep 14, 2012 at 4:52:37 AM
Revit 2014 - Disallow wall joins by default
Tue, Jun 17, 2014 at 10:23:22 AM
Level Split
Wed, Feb 1, 2012 at 4:04:32 PM
Page generation time: 0.6622
