73 Users Online (72 Members):
Forums >> Revit Building >> Technical Support >> Material Color Change not Rendering (...but Old one does)
16 Posts No Rating |
I have attached images to help explain: I have a material/texture I want to use, but I want to change the color on it...and I do. When I render, the old color shows up and the new color doesn't. Not too sure how to go about fixing this. ANY help is appreciated. Thanks, Jimmy
The part of the dialog you have circle defines the shaded color of item, not the rendered color. The material you are showing has an Accurender Texture applied. This will define the "Color" of the item in Renderings. You will need to actually modify the Accurender Material to get this to change.
2011 change material color [ 1 2 ] |
Sat, Aug 31, 2013 at 8:46:22 AM
16
True color rendering |
Wed, May 16, 2012 at 8:08:33 AM
change material color in linked file |
Tue, Oct 5, 2010 at 9:09:57 AM
How do you change the material and color of a download? |
Tue, Aug 6, 2013 at 7:31:46 AM
Change material and or color on railings |
Thu, May 5, 2016 at 9:30:10 AM
Members: | 1998849 | Objects: | 22885 | Forum Posts: | 152184 | Job Listings: | 3 |
