38 Users Online (37 Members):
Vertical Brise de Soleil (Sun Screen)
18132 Downloads
![5 Stars from 7 Votes](/images/stars_5.gif)
![](images/spacer.gif) | ![Vertical Brise de Soleil (Sun Screen)](object_docs/4523.jpg)
Vertical beise de soleil. You specify height, width, number of blades, blade angle and material. Metric. |
CSI Division: 08 90 00 Louvers & Vents RevitCity Division: Windows > Miscellaneous
Product Version: Revit Architecture 2008 |
Uploaded By: rmaciel
Uploaded On: Thu, Feb 7, 2008 Original Creator: Ricardo Maciel
Thu, Mar 12, 2009 at 11:19:33 AM
Joined Mon, Feb 16, 2009 No rating This user is offline |
When I try to load this into my project it tries to do a one time update process and then it fails. This is the case with many other components I try to load, and Ideas as to why I cannot load certain families into my file?
Fri, May 13, 2011 at 7:35:49 PM
Joined Sun, Mar 6, 2011
![3 Stars from 1 Votes](/images/stars_3.gif) This user is offline |
Is it possible to rotate this device so the louvres run horizontally? i seem to be having troubles doing so.
Mon, May 16, 2011 at 8:26:52 AM
Joined Tue, Apr 6, 2010 No rating This user is offline |
Just rotate it in the family, that will work:-)
Thu, Feb 22, 2024 at 5:47:39 AM
Joined Thu, Jul 31, 2014 No rating This user is offline |
Perfect, easy to adjust, looks great.
Thanks
Members: | 2018145 | Objects: | 22949 | Forum Posts: | 152183 | Job Listings: | 3 |
