63 Users Online (62 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Shear Tab/Plate Connection - Single Row
4507 Downloads
Shear Tab Connection (Single Row), full configuable, plate size, plate thickness, number of bolts,  bolt location, bolt size, etc. Required to be hosted to an element (ex. beam or column). Will cut bolt holes in beam with the use of the "cut" function under the "modify" tab.
CSI Division: 05 12 00 Structural Steel Framing
RevitCity Division: Structural > Framing > Steel
Product Version: Revit Structure 2013
Uploaded By: jacksobp
Uploaded On: Mon, Sep 16, 2013
Previous Versions
Product Version
Credit
Uploaded On
Last Edit
Revit Structure 2012
Fri, Aug 24, 2012
Mon, Jun 10, 2019 at 12:27:35 PM
WREKLESS
Joined Fri, Sep 29, 2017
CAN YOU USE THIS FOR DRAFTING VIEW ..2D??
Mon, Jun 10, 2019 at 12:27:39 PM
WREKLESS
Sun, Apr 3, 2022 at 5:39:49 AM
SharonAMercuri
Joined Sun, Apr 3, 2022
It is a nice picture post you shared here Single Row and it is good for us to find the best ideas that are good and more useful. When I used the dissertation writing service I found the best results with its help. When I used these resources I found it good and more useful.
Page generation time: 0.3424
