50 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> Pull up wall layer around corner
0 Posts No Rating |
As you can see in the attached image, I have pulled up my exterior brick veneer layer to just below grade. However, I can't get it to pull up at the corner. I have pulled up the two faces, but where the side wall, wraps the corner, it's still brick. I know I can just annotate over it with a field region to make it look correct, but I'm trying to avoid doing that.
RevitLT 2018
Thanks.
Mike
Try changing your wall joins to miter.
0 Posts No Rating |
Thanks, that worked. Created some new and interesting visibility issues to work through now.
Corner guards to snap to corner of wall |
Tue, May 13, 2014 at 12:18:44 PM
LAYER PULLDOWN |
Tue, Feb 14, 2012 at 3:16:22 PM
Exporting and layer modifiers |
Wed, Nov 16, 2011 at 4:04:33 PM
How to control a single-layer wall? |
Wed, Apr 28, 2010 at 2:39:50 AM
EXPOR LAYERS for WALL HATCHES are missing |
Wed, Mar 1, 2006 at 8:30:58 AM
Members: | 2000402 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
