51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> 3D Model to Extraction Model
Sun, Jun 8, 2014 at 8:26:41 AM | 3D Model to Extraction Model
bjwson
2.5 Stars: 3 Votes
Hi All,
i have a situation in Revit.
i have a model (let's call it 3D Model) and all my views, sheets & schedules in it.
now, the client wants 3D model to contain only model, that means he dosent want sheets in it.
he wants us to link into another revit file and have all sheets there, using 3D Model views (and he calls it Extraction file ie:2D)
I know the only way i can do this is, link the 3d model into a clean revit file, copy monitor all levels, and create the views based on those levels and in VG - Revit Links - custom - view (recall it from 3D linked model) drag those views into sheets......etc.
here, i want to mention, i have all sheets , views already existing in 3D Model & now i got to go through creating all that again.
is there any other way to kind-off import all the views (3d) into another model or am i left with the way i think is the only way.
it's a huge project, min. 200Sheets in it  Sad
pls. help
cheers
W
Mon, Jun 9, 2014 at 1:28:07 PM | 3D Model to Extraction Model
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
If the plan is to annotate, tag, dimension, detail and sheet elements from a linked file you are going to run into many problems. It's a BAD BAD idea.
Wed, Jun 11, 2014 at 2:38:01 PM | 3D Model to Extraction Model
bjwson
2.5 Stars: 3 Votes
i guess you did not get it completely, sheets extraction file is for sheets only, when you unlink or switch off all links nothing is shown. just a ER.
Cheers
W
Wed, Jun 11, 2014 at 3:17:51 PM | 3D Model to Extraction Model
HKicsak
Maybe I'm not understanding fully, but couldn't you just link your existing model into a new file? Then he would have  only the 3D information in that new file, and could use VG to control what is showing.
What is the purpose of breaking out the 3D model completely?
Or you could save as and delete all your sheets- that way only the views are in the model. This method would allow them to go elsewhere for design work without sharing who originally did the work, is that their purpose?
Using Revit2014, dragging the rest of the company with me from AutoCAD2008. When will the whining stop?
When to model stairs by level or as a vertical model?
Sun, Feb 19, 2012 at 2:03:43 AM
Can you turn lines into a solid or void extraction?
Tue, Apr 21, 2009 at 12:34:06 AM
superimposing model on a photo or adding background to a model
Sat, Nov 29, 2008 at 1:40:22 AM
Linking structural model to architectural model
Tue, Oct 9, 2007 at 6:05:11 PM
My model info just vanished, when I synched model
Tue, Mar 14, 2023 at 8:29:02 AM
Page generation time: 0.6834
